butt or joggled welding?
rustynuts
#1 Post by rustynuts »
Hi I am replacing lower 3" of my beetle doors and wondered if it was better to joggle or butt weld the joints. My main concern was not warping the door skins.
Cheers
Re: butt or joggled welding?
#2 Post by Luxobarge »
You'll stand less chance of a) warping and b) blowing holes if you joddle them - I know I would!
Cheers :D
lhubbard
#3 Post by lhubbard »
Im with Luxo there less chance of warping and all the hurt that goes with that.
cheers
lee
#4 Post by Luxobarge »
I'm sure you've thought of this, but just thought I'd mention it, I'd advise making the joddled lip so that it faces downwards inside the door, otherwise it will tend to trap water running down the inside face of the door. Seam seal it too, but belt-and-braces and all that.
Cheers! :D
rustynuts
#5 Post by rustynuts »
Thanks for replies folks. Yes I have gone the way of the plug weld as you all suggested. I did have a little go at both on a test piece and it was the neatest joint. I did face it upwards however on the door as it was easier to clamp the joddler in the vice and get it nice and even rather than fighting with the curved door. Plenty of seam sealer to follow though :) Then POR paint.
Thanks
rustynuts
#6 Post by rustynuts »
2013-03-28 16.08.00.jpg (51.8 KiB) Viewed 2125 times
Here is the offending article.
