MGB Fuel pipe
MGB Fuel pipe
In its previous life, my GT has had its main fuel line shortned by 3 inches under the car. I cannot find a braided fuel line to run from the pump to the main line as obviously, all the ones at Moss etc are now too short! Anyone got any ideas what i can do? Cheers
Re: MGB Fuel pipe
Use rubber fuel line, buy enough to cut a piece to fit. Most factors sell it by the foot in all of the popular sizes.
Can't see that it would need the braid as it's not a high pressure line.
Re: MGB Fuel pipe
Thanks for that, do I need a specific diameter of pipe?
Re: MGB Fuel pipe
I'm not familiar with the car, but it depends on how you're planning on joining the pipes.gt67 wrote:Thanks for that, do I need a specific diameter of pipe?
If the existing one is metal, with a fitting on the end, you could just extend it with 3 inches more metal pipe?
If you're not going to extend it & it has a fitting on the end, cut the fitting off & get new rubber pipe that fits over the end of the metal one.
If the pipe that's there is rubber, buy your new rubber hose in the same size so that you can fit a short metal piece between the two rubber ones as a joiner.
