Funny you should say that, Rich. No!rich. wrote:is this for your minor project john?![]()
Foam element not an issue. I have foam & scissors..zipgun wrote:![]()
We'll expect a new project thread to follow shortly after delivery ...Gis a hint why a vertical crank engine is so desirable
The foam element is shagged
The machine that will form the basis of "Project Frankenmower" is from 2007 so I shouldn't think it'll be considered a classic yet, especially as the MacAllisters are Mountfield AKAs along with dozens of other brands that the Italian manufacturer made for other DIY shop chains so they're the mower equivalent of Ford Mondeos; prolific, adequate, nothing exceptional to them but fit for purpose.
The engine, when cobbled into that deck, will allow the Mac (with suitable studs added to its tyres) to pull a seat, based around the chassis of my older Suffolk, so that I can then cut my own grass and sack the gardener.
I could also consider modifying the vertical crank engine and fit that, crank in horizontal orientation, to the old Suffolk but it's a barrel machine and when I've used it here it only succeeded in flattening the grass regardless of the gap I set between the fixed and revolving blades. So it would make sense to put it in a machine whose deck can accommodate it, whose belts will fit it and in which it will look almost standard. I might fit a modified exhaust system though, just for sh*ts and giggles.
