Noticed that the ignition coil on Freddie is getting hot, really hot, as in egg frying hot even while the engine isn't running.
Normal? (seems doubtful) or something wrong?
Hot ignition coil, but engine isn't even running!
Re: Hot ignition coil, but engine isn't even running!
With the ignition on, your coil is energised and will get hotter without the engine running than with. I can't claim to have done a temperature test but have noticed mine gets hot enough for me not to want to hold on to it if I leave the keys on while "tinkering"
If your coil is hot when you come to your car in the morning then you have a problem
Coil does only work off the ignition, but i see your point.
