Triumph Vitesse--will not start
robbie12
#1 Post by robbie12 »
Hi there,
this vitesse has been recenly fitted with--recon. coil, recon.carbs, recon distr. & new leads & plugs, but will not start
there is a spark at the dist. but no spark when i hold the plug near the engine block & fire the engine
all advice welcome
TriumphDriver
Re: Triumph Vitesse--will not start
#2 Post by TriumphDriver »
One step at a time then. If there's a spark at the dizzy then so far so good, it's getting from the coil but - it's not getting any further. There are a number of dodgy rotor arms on the go, so make sure both the arm and the cap are good with no cracks wear or other damage to the terminals especially the centre electrode. It can't be leads as there's bound to be ONE sparking out of all six? I'd suspect the cap and failing that, the rotor arm.
#3 Post by TerryG »
Or a duff set of points.
At least all the ignition parts are relatively cheap and easy to replace :)
#4 Post by tractorman »
It could be something as simple as the condenser in the distributor! Had that with a Herald about 40+ years ago and it took ages to find the problem (but I was 16 then!)
robbie12
#5 Post by robbie12 »
thanks for all your advice,
i finally tracked it down to a faulty coil
