for the bolt to go through the front mounts for the bolt
to take the weight and kick of the engine.
Only to realise when I went to put a bolt through that I
didn't have a bolt long enough! another item for the
shopping list!
I pushed the car forward and cleaned out the pit that the
car has been parked over for so long. All the leaves and
rubbish that has been blown into it.
Then I pulled the car back onto it. Yes I said pull, my legs
couldn't handle this but I used the end of the pit to hold
onto and pull the car back with a good grip of the tow hitch.
As I had used the grinder to cut the exhaust just infront of
the join after the cat, I thought it best to get the remaining
bit of tubing out of the join ready for the cat and pipe to go
back, the pipe needs to be a couple of inches than before.
I did place the A frame part of the rear engine and
transmission mount in place, so I could mark where it needs
a little trimming after it had been added to.
If I had realised how I was eventually going to fix it to the car,
I would have made the foot plate overlap the subframe, rather
than have to add the extra bits on to sort this mistake out.
