ok!!!
As far as I know this will be the 1st RHD Neon converted to a v6 and keeping it FWD,
not RWD  Talk about a learning curve!!!
The fabricating of mounts and brackets won't be a problem dad was a welder on the
rigs about 20+ years ago and still keeps his hand in.
It will be the electrics which will be the fun part!!
If i can bypass certain things on the voyagers wiring such as coded keys / alarm system,
then would only a couple of hundred for engine mounts and driveshaft mods, and
replacing the gear selector.
I found a pack of receipts in the donner vehicle that state an after market alarm and
tracker were fitted in 5- 10 years ago
(Haven't got it in front of me and can't remember the date)
Otherwise, the other option is Mega shift, and there is details for the 41te Chrysler 4 speed
electronic control online with it being able to be used with megasquirt II for the V6.
After a little more research I'm going to edge my bets and spend a little money(£47+ postage)
for the electronics to build a mega shift.
http://www.msgpio.com/manuals/mshift/index.html
It will be made on the cold winter nights on the dining room table,
near to a roaring wood fire.
So if yjhe use of the voyagers ecu's can't be used plan 'B' would be there ready!
