Rolls Royce Tyres
History
Rolls Royce Tyres
#1 Post by History »
The correct tyre for my car is Avon RR Turbo Speed.
These are £350 each.
I use Bridge stone at £95
The Avons have a stiff side wall and are set at 28 psi.
The bridgestones have a more compliant side wall so I use 32 psi.
The recommended psi from RR is called the crash in comfort setting.
Despite what some say a Shadow does handle and tyre pressures are only recommended.
Regards
Bob
Re: Rolls Royce Tyres
#2 Post by JPB »
History wrote:a Shadow does handle
Is it true that the rallying Shadows used factory suspension rates?
Here's oor Brian having some Shadow drag racing action from youtube: https://youtu.be/zpi4xRisgMQ
History
#3 Post by History »
I know of only one Shadow that was privately rallied.
The factory had 3 types of spring Boulevard, home and colonial ( how quaint) How ever one can have springs made. The front coils always seem fine. The rear coils on my car would benefit from a 10% up rate.
I fitted rubber coil towing things which made the car handle better.
The cheapest mod is to use 32psi all round.
Regards Bob
#4 Post by TerryG »
Shadows seem to do OK when you put one around a track
https://www.youtube.com/watch?v=EqkyyReXxgw
Personally I wouldn't as I tend to like my big comfy cars to be big and comfy rather than trying to pretend it's a track toy but each to their own.
History
#5 Post by History »
Same here. If I want to go fast round corners then a sports saloon would be better. I don't drive like that. However should I wish I can go faster around bends.
By driving slower I get to enjoy the car for longer.
Bob
Flatlander
#6 Post by Flatlander »
History wrote:The correct tyre for my car is Avon RR Turbo Speed.
Shouldn't that be Avon Turbosteel tyres on yours?
History
#7 Post by History »
Turbo steel not sure. A mate is visiting tomorrow. He has these tyres on his Bentley T1.
Regards Bob
Flatlander
#8 Post by Flatlander »
Feel free to correct me if I am incorrect.
I'm almost certain that RR used radial tyres on 15" diameter x 7" wide rims. As far as I am aware from other cars, the Turbospeeds are crossplies and not available for rims that wide.
The £350 you mentioned for the price would suggest to me that they would be Turbosteels, as that is a typical price for the 235/70R15. I only know that because they are the tyres I use on my classic. If you know where to go, then its possible to buy them for around the £200 mark, though the price does vary.
For mine, Avons are the only choice. Thats for the simple reason they are the only ones made today with the correct speed/load rating.
#9 Post by rich. »
this was the one on my transit...
Penguin45
#10 Post by Penguin45 »
Plenty of tread on that, Rich.
P45.
