There are 3 auxiliary sockets in there; one in the boot and two inside, one of which lives in the front armrest, the other in the ashtray.
The interior pair are on one fuse, which is present, the boot one on another, also in its correct place in the fuse box.
There's a supply at the incoming side of each fuse, and a cable present at all sockets, so somewhere, a connection needs to be made which connects the two front ones to their fuse and the boot one to its socket. Multiplug perhaps? I can't find a schematic for the car anywhere and VW themselves have been less than helpful as they didn't supply the car via a UK dealer.
It all looks hellish complicated behind the dash, so before I go wratching about testing for a suitable connection, does anyone on here own a Jetta or MK5 Golf 1.9 (non-PD) TDI 110 and know how to power their gadgets on the move please? In case it makes a difference, this is a DSG-equipped car and I'm sure that at least half of the entire loom is there purely to serve the needs of the gearbox and its ECUs, presumably the manual or auto versions would share the wiring that I'm trying to locate with the DSG cars though?
And lest anyone says the obvious; it was cheap, has done next to no miles and all works fine with the exception of the wretched aux socketry.
TIA,
