It seems as a matter of course to fit electronic ignition to old cars.
The sellers of the kits claim better starting betting running better mpg more power and more reliable.
I have found that the claims to be not quite true.
My car has points it starts from cold with a 5 second burst from the starter motor in 26 years of ownership it has never failed to proceed as Rolls-Royce say. Thats reliable enough for me.
Once warm the engine is seriously smooth and loads of power. The generator light is the only indication that the engine is running.
MPG is 11 mpg and 18mpg cruising on LPG.
Rolls Royce used to test engines on LPG because petrol washes oil from bores when cold. LPG needs no choke to start. I don't use any petrol.
max speed 118mph at 4500 rpm. O to 60mph 10 secs.
Bearing in mind that 70mph is max speed and 10 secs to 60 is not slow.
Fitting electronic ignition is of no use.
Plus points can repaired with a screw driver and I usually know whats wrong within 5 mins of checking. Electronic ignition does go wrong and when it does it resists fault finding and more than screw driver will be needed.
Looking after dizzys.
They are simple Machines.
First step fit and gap new points. Oil under the rotor arm and squirt engine oil under the base plate over the weights on the centrifugal advance. There is usually a small drain hole in the dizzy body so the oil will drip out, so too much oil won't hurt.
A 4 cylinder engine fires every 180 degrees (angle).
Opposite TDC mark on pulley make another mark.
Start engine run at 1000rpm set timing to TDC. Then check no 4 cylinder which should be the same as no 1. 2 and 3 should be the same but opposite TDC on the mark made.
They should all line up. If they do the dizzy is not worn and fit for service. Allow + or - 3 degrees max. This is called timing scatter.
The centrifugal advance.
The weights don't wear and don't change weight. Lack of oil can cause the pins to wear but providing the wear is slight it will be OK. The springs are often different from each other and last well but are not expensive so fit new ones and forget for 30 years.
The centfrigual advance senses rpm only it cannot sense engine load. This means that the makers specification is an educated guess because the designer doesn't know how the car is going to be driven.
My Shadow has no vacuum advance.
The vac advance does sense load. At idle an engine has about 21 inhg. This pulls the vac fully advanced as the throttle is opened the engine vac goes down and the vac module retards the ignition so that the engine can accelarate without pinking.
To check simply suck and if the base plate moves and holds until vac is released, then the module is good to go.
The rate is controlled by a spring. This spring does not move a lot and doesnt get particularly hot so last well. Oil again is good.
The function of the condenser.
Most professional mechanics and nearly all diyers get in to a tangle on this.
The ignition coil primary windings have resistance. The condenser is a capacitor. The values of the resistance and capacity form a capacitor resistor tuned circuit.
When the points open the primary discharges and charges the cap. The cap then discharges back though the primary windings. This happens 5 times. It is called ringing and because of 5 times tau 5. This appears on an oscilloscope as a 12kv spike then 5 small spikes at about 500 volts and fadding. At the spark plug the 12kv starts an arc which allows the condenser to maintain for 5 spikes at a lower voltage. In electronic circles they call this the RC time constant.
The spark plug starts the fire it does not add power.
Modern engines are designed to take advantage of electronic ignition. If a modern engine were to have its coil packs replaced eith a points dizzy then it would probably run not very well.
Old cars that have points were not designed to take advantage of whizz bang modern ignition.
Timing the spark.
My method is to warm engine. Set idle to 1000rpm. Advance dizzy till engine runs rough then retard till smooth plus 1/2 a degree for luck.
Drive a mph in a high gear and floor the gas. Any pinking retard 1/2 degree.. if no pinking advanve until it does then retard.
when refitting dizzys set engine tdc with no 4 on valves rocking.. turn dizzy so the points are fully open. This should give a bit of advance to start the engine. If the engine kicks then retard.
