What's this tool for ?
Found a set of CK splined end sockets, not Torx or 12 points , but would fit a circular hole with "pegs" around the inner circumference . Anyway , what are they called / for ? The owner had a Citroen Visa, are they a special tool for that?
Re: What's this tool for ?
Locking wheel nuts?
Similar, but a set of five or six , in graduating sizes ,on a rail , the largest being about 10mm dia ? Look similar to the end of a first motion shaft in that the clutch disc drives , a round shaft , with grooves milled down it ,equally spaced .
Any chance you could post a picture of the thing to which you refer please?
Perhaps surprisingly, there are very few "special" tools required for any Citroën, there's always a conventional way that costs half as much. Most things are extremely basic on the Visa and the usual advice (unless you're replacing the flywheel sensors on an A-series version**) is "use a larger hammer.."
**If you are doing that, use the hammer gently and with more care!
Autoshite came to the rescue ! It's called a Ribe bit ! Alfa Fiat & vw use them. http://autoshite.com/topic/19018-spline ... -what-for/
I have a set of those. now I know, lol.
I'd have recognised that if Mercedes at Coldstream had carried out the warranty work they were meant to do to my Smart ForTwobutnotforonefatc**t! (New driver's seat base, etc. I can't help it, it's glandular, OK)...
I reckon a half decent bodger could fit a Torx bit into one of those, with the appropriate BFH!
