scimitar gte rear axle
trickey33
#1 Post by trickey33 »
Hi does anyone know which rear axle was fitted to the scimitar gte range some one told me it was a ford ,I have been offered one to use in my 70s hot rod that I am building ( restarting after 35 year lay up)
Re: scimitar gte rear axle
#2 Post by JPB »
Depends on which bills Reliant had paid at around the time the car was built! I believe that many use Ford diffs but some used the TR6 diff, both in axles with MGB hubs and bearings. Reliant World forum will have all of the definitive information on this.
Classic Microcars
#3 Post by Classic Microcars »
Better still, Scimitarweb. The axles were Salisbury starting with the 4HA, with a range of final drive ratios.
#4 Post by JPB »
Classic Microcars wrote:Better still, Scimitarweb. The axles were Salisbury starting with the 4HA, with a range of final drive ratios.
That assumes that the O/P is registered there.
Classic Microcars
#5 Post by Classic Microcars »
Registration isn't an obstacle is it? Most of the articles don't even require it.
#6 Post by JPB »
'Fraid so. The technical info wiki requires registration. :(
Talking Hoarse
#7 Post by Talking Hoarse »
Interesting aside (well interests me at least). I understand that Scimitar rear axles were used /homologated by DTV for use in Vauxhall Viva /Firenza /Magnum rally cars in 1970's. This then (I think ...) got a Jag spec Sailisbury LSD into the rally car.
