braking pulling to right
- chrissyboy
Hi all, nice to see the forum back..............
Anyways, my query: when hard braking car is pulling to the right. Which calliper do i need to work on? its due MOT nxt month and it needs sorting
Eyup!
Re: braking pulling to right
The right....the car is trying pivot around the wheel thats doing most work.
I'm afraid I disagree - it's the left one that's not working, allowing that wheel to go "straight on" as it were - the working right one is pulling the car in that direction.
Cheers!
Cheers!
I'm with Luxobarge, sounds like the left-hand one isn't as effective as the right, so you should investigate the left!
conversly, it could be the one on the right that has a collapsed flexi pipe, making it brake harder as it's bindingLuxobarge wrote:I'm afraid I disagree - it's the left one that's not working, allowing that wheel to go "straight on" as it were - the working right one is pulling the car in that direction.
Cheers!
1989 BMW E30 2.5 Tourer - Daily
1970 MG Midget - resto nearly finished
1978 VW Type2 twin slider - getting there, see link above ^
I could see how a collapsed pipe would make it stay on (bind) after a braking event, but I can't see how that would make it work harder than the perfectly working caliper on the other side. If the efficiency of the pads & caliper were the same on each side, then the braking effort in each wheel is in direct proportion to nothing other than the hydraulic pressure, and a collapsed hose can't deliver more pressure than a working one! If the efficiency of the pads/caliper are not the same on each side, then that's the fault, and the inefficient ones will be on the left in this case.spiny wrote:conversly, it could be the one on the right that has a collapsed flexi pipe, making it brake harder as it's bindingLuxobarge wrote:I'm afraid I disagree - it's the left one that's not working, allowing that wheel to go "straight on" as it were - the working right one is pulling the car in that direction.
Cheers!
Actually, the answer to the question is that you should work on both sides, because if you sort/fix/re-furbish the faulty side (the left
Cheers!
- chrissyboy
Lux, you speak a lot of common sense as usual, so I'll clean both. Thanks all!
Eyup!
un-amusingly enough, the brakes on my E30 have developed a fault today too, so I will be joining you in swearing at siezed retaining pins etc etc later on ...
i was thinking of a faulty brake grabbing first not the one working last.
When I had a stuck caliper,I felt the front wheels as the heat travelled from the hub.
