Hi all,
Have just moved house..can anyone recommend a good classic friendly garage in Hythe / Totton / Southampton/ Brockenhurst type area?
Don't need it yet but you never know!
Cheers all
col
						Hampshire / New forest area?
Re: Hampshire / New forest area?
Might be a bit far out, right on far edge of the Forest, but I can highly recommend Steve and the rest of the lads at Sopley. It's the only place I use, and I happily trust them with both the classic and moderns for the MOT and jobs I can't be bothered to do. If it helps, it's about 10 mins away from Burley, which is about 10-15 mins from Brock if that helps with distance time scales
http://www.sopleygarage.co.uk/
Hi Mach1Rob
Many thanks for both bits of info you posted.
cheers col
cheers col
