Instrument bezels
StephenL
Instrument bezels
#1 Post by StephenL »
HI, I want to replace all the bezels on my guages, which i thought would be easy, but I'm really struggling to find a supplier. I would have expected this to be quite a common want>?
Anyhow, I'm after the usal 52mm, as well as a speedo (around100mm) and a clock that comes in about 60mm. These are known as "half V shape" and I want teh standard black.
Can anyone help with a supplier? I once had a flier from a guy who had a stand at Beaulieu but it got lost in a house move :-(
Ian
Re: Instrument bezels
#2 Post by Ian »
try http://www.holden.co.uk/ they should be able to supply what you need, otherwise try https://www.europaspares.com/
#3 Post by mach1rob »
Could you not strip down the gauge, rub down the bezel and repaint yourself?
StephenL
#4 Post by StephenL »
I'd rather not because they have little tabs that have to be pulled back to separeate them from the instrument which once you do it a few times ruins them. I've got from holden (thanks for the tip) all the bezels i need for my TVR and Scimitar except one odd sized one which I will have to repaint best I can. Not cheap;it's easy to run up a £100+ bill for a few bits of bent tin as I have learnt :( :shock:
#5 Post by mach1rob »
Typically, I had this turn up in my inbox yesterday from AES! Should have what you need
http://www.autoelectricalspares.co.uk/g ... s-68-c.asp
