I followed the procedure in the workshop manual, that said to disconnect all the wires from terminals A &A1 and join them together. Then with the voltmeter between D & E, I set the output screw (The output points especially were tarnished through years in a box but they took little cleaning and I reset the gap), ensuring to do it quickly, so as not to overheat the shunt windings. It wasn’t a very warm day and I set the output to just over 16V. With this done, I set the cut out to about 13V. All seems to be well.
All my previous cars have had alternators (Even my 1974 Mini had one), so the dynamo is a relatively new thing for me (I remember my father’s Lotus Elan had one). I have looked at the wiring and can see what goes where but I am curious to know what is the purpose of joining all the A and A1 wires together
Also the settings had a tolerance (The output was temperature dependant) and in the case of the cutout, it was something like 12.7 to 13.2 V, so I aimed for 13V. I know that without the cutout, the dynamo would turn into a motor at low RPM and with this in mind, wondered whether it is better to aim high rather than low
