Ok so when it comes to oil in a classic I hope we are all using 20/50 (or 20/winter50) unless you have a 1940’s steam tractor or something! Even then you may benefit from changing the SAE30 to 20/50…. I assume we all understand that 6 months, 3 thousand miles changes are no longer needed. We all change our oil yearly, maybe at 6-10K miles.
You have 3 choices,
Supermarket cheapness, Tesco, Morrisons, Asda, Wilkinsons. About £7 for 5 Litres.
there are the mid range classic oils from Halfords, Comma, Castrol. About £17 for 5 Litres
Then finally prestige blends like Millers, Morris Pentright About £20+ for 5 litres
All of these oils comply to the same SAE standard, or they cant be called 20/50, they all seem to comply to the additive standard for 20/50, they all look and smell about the same…. But some come in nicer boxes.
So, Why the hell am I putting £17 Comma Classic in my 67 S-Type? When Tesco’s £6 is the same?
Here is my opinion.
I am going to use Comma Classic or Halfords etc on my 67 S-Type, because its had an engine rebuild and spending an extra £20 each year to know that I have given my £3K engine rebuild the best chances of survival is worth it. I don’t think its worth putting the more expensive custom blend oils in…(mainly because the machine shop said not to)
HOWEVER on my DS420 Hearse, (same engine, XK Jaguar/ Daimler) but not rebuilt and a bit of a rough smoker of unknown history, I am going to use Wilkinsons £6.99 stuff. My rational is that its an old smoker anyway and I am not sure how much longer it will last so saving £20 a year is worth a pop. I think it’s currently got 15/40 in it! So that can go for a start!
That’s the game I am going to play, what will other people do?
