Only about 111k miles so hardly run in yet!
It looks like someone else may have been after her as well I found this on the ground after removing the front carpets.
I've always known that a bulkhead swap or extreme repair would be in order, which way should I progress?
As soon as I mentioned to Biosbill what I was getting he said that the rear doors would probably need replacing... I think he was right!
Today I tried to go to halfrauds to get a 150 piece socket set but they apparently had some in stock but couldn't find them :S I had a good poke around with the hammer and found the front out riggers also need replacing and the rear crossmember might need to be repaired (it's been previously replaced). And started to remove the side steps as they're rusty bent and getting in the way.
Thats all folks, if you have any questions or comments I'll try to answer them but I'm posing this on LRO, Landrovernet, Young Guns Classics and Practically Classics so might not have chance for a while.
Oh and my aim is to be road worthy by October....
David
