Bloody moderns
Re: Bloody moderns
#11 Post by JPB »
I use cable ties occasionally when I have a recently opened packet of choccy hurb nurbs, have only eaten a couple and want to put the "lid" back on, having pulled the red string carefully so allowing myself a good re-closing overlap.
Usually, at least half a pack goes at once, :oops: but, when fewer of the deliciously crunchy sweet snacks have been eaten, a rubber band isn't long enough to reach around without causing breakage so out come the longest of my reusable the wraps to hold the lid on and job's a good 'un.
But cable ties as alternator belt substitutes? That's one for Ted Connolly's column! :lol:
zipgun
Re: Bloody moderns
#12 Post by zipgun »
I only had a dog lead, which would have worked , but i don't know how to do a lorry driver self tightening knot !
Re: Bloody moderns
#13 Post by JPB »
zipgun wrote:..i don't know how to do a lorry driver self tightening knot !
Me neither, but as I've yet to feel or act on the urge to murder a prostitute, this hasn't been an issue. :|
mr rusty
Re: Bloody moderns
#14 Post by mr rusty »
Mrs Rusty's modern...three bolts, headlamp out, 5 mins at most, back lights? Open little hatch in boot, easy. Ye simple olde Vitesse on the other hand........fronts are sealed beam, but the hassle would be the same if they were bulbs- front headlamp panel off, headlamp mounting bezel off, headlamp finally out. Not too much kerfuffle, but not as straightforward as you'ld expect!
One of my neighbours has an old shape Punto- rear lamps need a special tool......which should be in the toolkit but, as expected, once we found out about it's supposed existence it wasn't there, making the job more or less impossible without breaking something :x
