A couple of years back I rescued this old Crypton Motorscope 335 from my local garage. They had it buried on its back half under an awning. They hadn't had the heart to bin it after many years of faithful service. Who says mechanics aren't sentimental?
Despite currently being buried in my garage, it's actually proven really handy on a few occasions...though practicality aside, I knew I had to rescue it the moment I spotted the huge rank of flipdot buttons. The Panaplax digital readout above the analogue meter was an unexpected bonus. I'm a bit of a display tech nerd and it was the first time I'd seen that technology in person.
Essentially it's a very specialised multimeter with a scope and timing strobe attached to help diagnose ignition and charging system issues. A CO% meter was an optional accessory...sadly not fitted to my unit.
She needs a little love as the button contacts are scratchy as hell and a little percussive maintenance is sometimes needed to wake it up...I suspect it needs a decent dose of contact cleaner and the various card edge connectors similarly cleaned. Given I spent about half an hour reviving it and it had been half exposed to the weather for God only knows how long it's doing very well.
However, I stumbled across something which has been on my wishlist ever since I saw one a long, long time ago...
Functionality aside...LOOK AT IT!
I'm a complete sucker for that flat smoked panel with chrome trim aesthetic...best exemplified by the Kolster Brandes KV-024 television (circa 1968) which was my gateway into proper vintage technology restoration - and the first valve based device I ever played around with.
Sadly that's currently in hibernation in the back of the loft as it needs a new CRT...and they're not something you exactly trip over these days.
I was expecting this to go for ridiculous money to someone with far deeper pockets than me, only to be gutted and have the faceplate wind up on the wall of some trendy office.
So what was the end result?
Well that was a surprise! Just the starting bid.
So a van has been booked for Monday to go and collect it. Roughly 80 miles each way, so not even far away.
Given the fact that these things weigh about as much as a small country I decided it was worth spending the extra £15 to go for a van with a tail lift...my spine will thank me for that.
Basically this has the same scope functionality on the left hand side as on the old Crypton unit - though what's different here is that instead of a glorified multimeter on the right, there's a CRT hooked up to a rather primitive microcomputer. This allows you to do quite a bit more detailed analysis of the data gathered. Including stuff like recording the current drawn by the starter motor during cranking to give a rough estimation of the relative compression ratio of each cylinder. In addition there's a CO% and HC exhaust gas analyser built into it. This is an optical type as well, so there's a good chance that with a proper service that it will work just fine.
Here's an example showing the display in action (from the user manual). This is the earlier version - identical as far as I can tell aside from the cosmetic differences.
Rather looking forward to getting that in the garage...been a while since I've had a decent tech project.
Folks want me to video the initial inspection when I get the heavy sucker of a thing home?
Done a little more work on the heater install in the van. One thing which was bothering me was that the exhaust was pointing out to the side...the gases expelled from it are HOT and I was worried that it was a hazard that someone was going to burn themselves on. It also had a serious habit of pointing exhaust directly at my mains hook up cable. The pipework didn't want to let me point it downwards...so I had to improvise.
Discovering that 22mm pipe was a perfect snug fit in the silencer outlet made things easier.
Though the question springing to mind was whether the solder will melt...no idea how hot the thing runs. Only one way to find out is to hook it back up and fire it up.
Yes... it's melted the solder. I'll just replace the elbow with a compression fitting tomorrow. Not too worried about the pipe into the silencer as that's a very snug fit, and a quick tap with a hammer and punch should make sure it's never going anywhere.
Still really impressed with how quickly it warms the van up...and glad to report that the comedy smoke cloud on startup has stopped being produced now the fuel pump has been properly primed.
