Thanks Mitsuru, i checked that website but it didn't cover my car
. I found the oil leak and bought a new gasket for it so next time I change the oil I'll put it on.
I have a different question. My radio is driving me mad
As my car is a diesel I have to heat it when starting from cold, the radio keeps the stations up to the point of the ignition lights, but the minute I turn the key it loses the plot. however if I start from hot and just turn the key it's fine (mostly)
WTF!!! I found a "Radio Setting condenser" for a Toyota Carina E 1.8 16V on Fleabay. I asked the seller where this was located and if my car had this, he just told me it was under the bonnet
So I have tried the trick with a 9V rechargeable battery connected to the permanent live wire and all it did was nearly blow up the battery
I don't want to buy a 12v battery from Maplin if a simple plug in condenser will do the trick.
Any ideas?
