computers
Re: computers
#91 Post by rich. »
tried that, it took me a week to find the off button :lol:
Re: computers
#92 Post by rich. »
hello again chaps, im trying to download a programme for my old epson scanner & its asked me whether its windows 7 32 or 64 bits?? im really confused now could someone please explain the difference??
edit! please use words i can understand :lol:
Re: computers
#93 Post by TerryG »
assuming you are running windows 7 ;)
press the start button
right click on computer
press properties
a program will start running
in the middle there is a section labelled "system"
there is a row labelled "system type" it will say either
"32-bit Operating System"
or "64-bit Operating System"
if it says "32-bit Operating System" then you have a 32-bit Operating System, you can work out the rest for yourself ;)
Re: computers
#94 Post by rich. »
thanks mate.. i managed to do it although the scanner doesnt want to play ball now!!
Phil P
Re: computers
#95 Post by Phil P »
Just started running Windows 7 Home...something. It's quick but Word is far too fussy. I'm having a problem loading me AutoCad 2002 on it. Basically it doesn't want to know and AutoCad doesn't support it. If they think I'm going to spend £6/7K buying a new AutoCad they can bugger off!! I've still got my drawing board and kit!
Re: computers
#96 Post by TerryG »
Hi Phil,
have you tried compatibility mode?
You can use Window XP mode (which is a bit of a pain and no longer supported so don't surf the web from within it!) if all else fails.
Phil P
Re: computers
#97 Post by Phil P »
Cheers Terry. It's probably because my copy has a striped shirt and a patch over one eye! :shock:
Re: computers
#98 Post by rich. »
:lol: :lol: :lol:
jimmyybob
Re: computers
#99 Post by jimmyybob »
I had the same problem with an old epson film scanner even with a genuine windows copy and the original driver disc it still wouldnt work with my laptop and epson no longer support it either.
Re: computers
#100 Post by TerryG »
you should never use the supplied software / drivers with any product, they are always out of date even when the machine is new.
Epson may not have 64 bit drivers for your scanner but x86 Windows XP drivers usually work in Windows 7 (x86 version) even if it complains about compatibility while installing.
