The autobox finally went kaput a year ago. I fitted a manual MG Metro engine and box I had kicking around. Before I fitted it I changed the final drive ratio to 3.94:1 to suit the bigger wheels. The 3.94 was hard to find. I searched all over the world only to find a Mini specialist 40km away had three NOS sets in that ratio on the shelf!
Unfortunately the MG Metro engine just about generates 10 psi of oil pressure at hot idle, and the gearbox has decided it likes to jump out of second gear. So it will need removal again next year for a rebuild.
I had the exhaust changed to move the muffler over to the left and up high out of harm's way. Then I added a second stainless steel fuel tank in the rear subframe to double my fuel capacity. I'm pretty happy with the result although I may rework the number plate flap.
I want to house the extra fuel gauge better but this little pod will do for now.
The switch to change tanks. It controls solenoids on the line form each tank that open when 12v are applied. A y-piece connects the two lines before the fuel pump.
Cheers,
