Mornington Crescent, anyone?
Re: Mornington Crescent, anyone?
#2321 Post by JPB »
Phil P wrote:Oh I forgot I am male.
I once did that but it was OK 'cos when it came to court the judge recognised me from one of his "special" parties. :|
S, are you by any chance famous aeronautical engineer Neville Shute-Norway, better kent as novelist Neville Shute?
Phil P
#2322 Post by Phil P »
Sorry not to get back before but I have been away for the weekend.
No I am not Neville Shute. I started off in aerodynamics at the Bristol Aircraft Co. I went into car design in 1950 and introduced the slide rule into designing compound curves when I moved into car design and used my aeronautical background.
arceye
#2323 Post by arceye »
Would that be a Jaguar connection?
Phil P
#2324 Post by Phil P »
Yup!
arceye
#2325 Post by arceye »
Would that be in the design of the E type then?
Phil P
#2326 Post by Phil P »
Not just the E type. My first design was in 1950. The family resemblance can be seen from then.
arceye
#2327 Post by arceye »
Well then my good man, in that case my spidey senses are telling me that you are...
Malcolm Sayer, designer of the C / D / E Type, XJ 13 and the XJS Jags ?
Phil P
#2328 Post by Phil P »
Sir you are correct. I therefor declare you IT
arceye
#2329 Post by arceye »
Sorry for the delay chaps,
I shall then, be R
Male
Dead
Not Britsh
#2330 Post by TerryG »
Hello R, did you pass away in the last 113 years?
