Hi,
The accelerator pump on a Solex PSEI carb of a Super Minx isn't working. I have changed the diaphragm & spring and blown through with an air line to ensure no blockages from pump to swan necked jet.
Any other ideas where the problem might be?
Cheers
Accelerator Pump
- Dazman1360
- Contact:
Re: Accelerator Pump
It's likely that the accell chamber is not filling then. A carb strip and clean job to degunge the float chamber passages would be the next step IMO. If you have access to an ultrasonic cleaning bath in a local garage that would be best but copius spraying with carb cleaner and an air jet should get things flowing again.
- Dazman1360
- Contact:
The chamber with the accelerator pump/diaphragm does seem to fill with fuel as when you remove the cover fuel does drop out.....
