So thought initially a leak of brake fluid & another issue (the noise). On investigating I found the brake calliper to be as dry as a desert. So thoughts came to, inner bearing seal letting by, hyphoid oil diluting bearing grease = dried out bearing.
Well getting a bearing off of a half shaft is well beyond me. Let alone pressing a new one on
So I pulled the other side:
Check the rollers that just fell out! Well tatered
The 'sad' part is that the outer race (?) of that bearing has stayed in place within the axle tube & is is being a git to remove:
In short this could for me, be the end of my beloved 'Tank'. If I can remove this 'bit' I can put in a replacement 1/2 shaft.
I am told 'Tank' is too good to scrap':
I agree, but it is my ability that is concerning me as I'm getting a bit out of my depth. Costs at a garage make it out of reach too. Any suggestions as to how to remove that bit (which may have welded itself in place), or any other ideas are more than welcome
