MGB wipers
Posted: Sun Apr 17, 2011 9:28 pm
by ate1980
Hi,
My wipers park vertically blocking my view, rather than horizontally. What could be causing this ? they definately "park" as where ever i switch them off they always end up in this position.
Thanks
Re: MGB wipers
Posted: Sun Apr 17, 2011 11:09 pm
Someone has put the arms on in the wrong position. "park" the wipers then spin off the nuts that hold the arms in place, put them at the bottom of the screen and do up the nuts again. :)
Re: MGB wipers
Posted: Mon Apr 18, 2011 12:09 am
No nuts on the wiper spindles, Terry. They're splined, like Minor ones....
One slight flaw with that suggestion is that, if the wipers were both fitted in the wrong position, they'd sweep off the end of the screen by the same amount as that from their park position to where they park, and they'd stop short in their sweep the other way.
This is more likely to be an issue around the position of the self parking cam on the gearbox, relative to the position of the pin that connects the gear to the rod that drives the rack back and forth.
