Headbolt torque talk
Posted: Thu Feb 20, 2014 11:59 am
by zipgun
Gotta be quick answers , i'm going to do it as soon as the rain stops ! Cinquecento head gasket.. Torque to 22ft lb stage one, bolts 12345678 ok? Then 90 degrees stage 2 , then another 90 degrees . Right ,during 1st stage , do you torque just the once, because by the time you get to bolt 8 , bolt 1 is somewhat slacker than the 22 ft lb it was tightened to already. Should they all be 22 ft lb before stage two , do you go round 2nd time before stage 2?
Re: Headbolt torque talk
Posted: Thu Feb 20, 2014 12:40 pm
by Penguin45
I'd go round twice.
P45.
Posted: Thu Feb 20, 2014 12:52 pm
by Luxobarge
Likewise, I usually go round twice. Only takes a couple more minutes eh?
Cheers!
Posted: Thu Feb 20, 2014 4:22 pm
by zipgun
Thats good ,coz thats what i just did !
I got this 899cc Cinq 4 years ago at 29k for 120 quid with a blown HG . Picked it up at 9am , took it to bits, took the head down and had it skimmed , all back together by 1pm. Its since done another 30 thousand , just blown the HG again .Only slight misfire upon starting ,last couple of days . I did torque twice first time i did it , before stage two and three...Anyway all back together now, seems honky dory
Posted: Thu Feb 20, 2014 5:32 pm
by megadethmaniac
how on earth did someone blow a fiat Head Gasket at 29k?
Posted: Thu Feb 20, 2014 6:48 pm
by zipgun
Dunno , an old biddy had it... full Fiat history till 29k . Then i got it
Posted: Fri Feb 21, 2014 1:59 am
by Penguin45
Actually...........
Say your torque setting is 75 lb/ft for the head bolts. I'd probably do 60 lb/ft twice. You know the head will be down and evenly flat, then do 75 lb/ft just the once to finish the job.
P45.
