Chevrolet 350 on to a HP22 autobox?
Posted: Mon Dec 23, 2013 7:13 pm
Probably a question for Harvey,
Not that I have been nosing around a friends garage for a few hours today or anything but I have found a 350 small block and obviously the first thought that ran through my mind was "I wonder if that will fit in my range". Ignoring everything else I should be doing, more power is always the top of the priority list (behind fixing the damn brakes!). I know that a 350 will physically fit under the bonnet as Overfinch did it for years but if I were to bolt it to my HP22 gearbox, will I lunch it as soon as I put my foot down? Assuming so, can the valve block from a 22 be fitted to a 24 to remove the need for a gearbox ECU and is a 24 up to it or would a completely different setup be needed?
