Rover 100 Knightsbridge SE
Posted: Thu Aug 09, 2012 7:47 am
Recently purchased from MGMal, this is intended to be my eldest daughter's car once she has learned to drive next year/early 2014. I know it's a while off but it does give me time to sort a few little issues.
The car is a 1996 Rover 100 Knightsbridge - 3 door with 1100cc of 8valve K series engine, 5 speed box and just 22,700 miles on the clock from new (backed up by some service history). Overall it's in pretty good nick - the engine is smooth and very quiet, the front and rear arches are excellent apart from a small area on the right rear, brakes and steering seems OK but the clutch feels a bit sticky (probably the cable). There is no rot in the boot corners, doors or wings and the underside is generally good with just a couple of small holes in the floors. The radiator looks good, the fan cuts in at the right time and the temp stays under 1/2. The interior is pretty good apart from failed stitching on the driver's seat base and a few headliner issues (well, it IS a Rover). It should make an excellent project and equally good first car.
Jobs to do include:
Service - including precautionary cambelt change - possibly water pump, too
Fix a few bits of trim: driver's seat base, headlining and door card (door card already done)
Repair small areas of rust on the right rear arch, rear valance, floor and scuttle panel.
Fit new stereo (the display on this one seems to have failed)
Fix nearside central locking
Replace rear tyres - legal but old and mismatched.
Change heater blower (it vibrates like mad - probably bearings)
Change front and rear screen seals
Rustproof!!!!! It IS a Metro and is currently quiet good so I'd like it to stay that way.
Precautionary water hose changes
Plus some other stuff that I've forgotten!
1100cc of raw power!
Nice clean coolant
Scruffy bulkhead
Scabby scuttle
Rot free boot corners - most Metro owners know all about this area's problems
Holed floor
Wheel arch
Jobs to do include:
Nice clean coolant
Scruffy bulkhead
Scabby scuttle
Holed floor
Wheel arch
