Engine Parts Cleaning
Hi all,
I've started a rebuild of my motorcycle engine and have started with the oil pumps. I have cleaned them in a parts washer but I still don't consider the parts to be clean enough. What is the best way to clean small parts on a DIY basis? I've done a search on the internet and within this site but can't find much advice.
Any advice gratefully received.
Many thanks,
Dario
Many thanks,
Dario
Re: Engine Parts Cleaning
A dishwasher is the best ever way to clean those smaller parts. I've had most of a Fiat 500 engine in mine and that came out clean (and free as the heat expanded the barrels just enough)....
Seriously, they're ideal and as long as you don't want to wash your pots at the same time, there's possibly very little actual health risk involved.
Ultrasonic tank? I clean all my clock parts after dissasembly in one with a pretty nasty ammonia solution available from horological suppliers. Takes off old laquer / varnish and dirt with little trouble and gets into nooks and crannies no bother. I'm sure theres other cleaning fluids available also.
How big a tank would be the issue, mines about 5 litres and would take something around the size of an SU carb as an example.
If you can get some, paraffin is really good for getting crud and oily deposits off engine parts. Thinners is good for cleaning carbs or if you get some proper carb cleaner that is really good stuff!
1971 Sunbeam Rapier H120
Yes, but I have the dishwasher because I'm currently single and not the other way round!suffolkpete wrote:You must be single![]()
Seriously, give it a go. You can steam a whole salmon in a dishwasher too. That makes a far worse smell than cleaning a few bits of oily metal.
Well, I'm not single and we have a dishwasher, whats more I don't reckon the wife even knows where it is
Damn her ill health.............Damn it to hell
Still, as I'm also in charge of the cooker, I can tell you it makes a damn fine parts dryer
Thanks for the tips guys, I'll give some of them a try.
Dario
Dario
John - what flavour rinse aid works best with salmon?JPB wrote:Yes, but I have the dishwasher because I'm currently single and not the other way round!![]()
I have heard of using a dishwasher to clean up old lamp lenses, make them sparkle etc but never had the courage myself - a) because it is our dishwasher & b) because the lenses in question are very hard to replace.
Be cautious though as some steel & alloy cooking utensils are corroded in the dishwasher.
Ed
