I was looking at how to display what gear the automatic transmission
was in, but realised that as the system would need to read the bus
system that most cars have I could just show what option the gear
selector was in!
Which means that this info could be used for manual or automatics
gear indicator.
Here is a list of parts you will need.
-6(maybe more depending on where you decide to mount them) Off in resting position magnetic switches.
-A butt load of wire
-27 diodes
-7 5200ohm resistors
-PC board
-Enclosure box
-2 female 9 pin connectors
-2 male 9 pin connectors
-solder
-15watt iron w/ very small tip
-very good soldering skills
-several burns and curse words
this circuit needs to be made VERY small so you can hide it in enclosure and hide it under the cup holder/shifter area.
please note I nicked the above from the Honda civic forum
http://www.8thcivic.com/forums/do-yours ... cator.html
But if I use one of these I would get a good set of capital letters.
P, R and N
