Dying the death.
Posted: Sat Nov 12, 2011 4:08 pm
Right, long story short, Triumph 2500 PI, but now on twin SUs.
Starts, runs fine, drives OK no bother. Can go off for a nice drive, then it will just die, cuts out like its run out of petrol. Glass fuel pump on side of block has a healthy level in, but the plastic in line filter just before the carb can appear to be empty. It will just crank over as normal, no hint of starting. Leave it a few minutes it will start.
PO has replaced the points and condenser with an electronic set, Pertronix I think, 60 odd quids worth, so not the cheapies off evilbay. I have replaced the coil as it looked to be the original, and of course, Triumph use a ballast resisted set up, this has been bypassed and its running the full 12v, it's had a new cap, but rotor hasn't been replaced. I have heard of some being temperamental, and the contacts breaking when they get hot and expand, but before I order a replacement, has any one else any other ideas?
I set the carbs up last week, and its running much sweeter, but this cutting out is beginning to **** me off!
