Bnicho's 1971 Morris Mini Moke.
Posted: Sat Feb 05, 2011 7:49 am
Here is my 1971 Moke I call Mopoke.
It's my favourite car, because it's such a hoot to drive and it attracts so much attention.
We have a lot of fun together and I don't mind if she gets the odd paint chip.
Mopoke is a constantly evolving project. I like to fiddle and change things all the time. The latest is the custom dashboard, and the seats will be changed very soon.
Specs:
1990 1275 A+ with four speed auto
HIF38 carb, sports filter, extractors
Nissan Pulsar ignition.
Honda City Front Disks
Hotwire 13 x 5.5 mags with 185/60 Yokohamas
Custom roll bar to CAMS (FIA) specs.
Home spray job in a Ford Yellow. DIY, so it's not great.
Inside and engine bay done in "Panelfleck" to resist chipping and make it easy to change colour if I decide Yellow is too common.
Why the Auto?
I drove a mate's 1275 Auto Mini years ago and loved it. So I decided I wanted the Moke to be Auto someday.
When I started building it I fitted an Auto subframe, planning to fit my spare 1100 manual (with spacers on the engine mounts), then fit an Auto later. But then another mate happened to be offered a low km 1990 1275 A+ Auto at a bargain price. So the 1100 is still in the shed, and the 1275 Auto is in the car.
The Auto is surprisingly smooth, and it downshifts when you slow down, like a modern car. You can also shift manually when you feel like it. It's great.
Yes, it saps some power, but when the car only weighs 550kg, you don't need much power to have fun.
The Auto has a 3.2 diff, but like all FWD A series autos the drop gears are not 1:1 like a manual. So the gearing works out overall at about at 3.7ish (can't remember the exact figure). With the lower rolling diameter tyres (185/60R13), that makes the gearing similar to a manual Mini with 165/70R10 tyres and a 3.2 diff. I find that a good compromise between acceleration and top speed. She sits at about 3,600 at 100km/h - our usual open road limit.
It doesn't seem to be sluggish at all. It takes off smartly and it does hold on to the lower gears if you keep your foot down. I'd say performance is better than a stock 1100 Moke, but not as quick as a stock 1275 manual.
Having said all that, I'm building a twin cam 16 valve A series with bike head and carbs....
Cheers,
Brett.
Specs:
Why the Auto?
Cheers,
Brett.
