I'm saving up the pictures to do a big update once I've finished the welding, so this is just a little "I'm not dead yet" post. Yesterday I finally completed the welding to the driver's floor front and rear which looks tidy and is far stronger than it was when I bought the car back in 2012. The weekend before I put the sill repair section on and build a wheel arch repair section from scratch. It's not Grumpy Northerner standard of work, I haven't the experience to achieve that and my fabrication skills are merely okay, but it is solid and with a little more fettling the visible bits will be invisible again.
I've got a repair panel to attach to the bottom of the front driver's wing, a section of outer sill to repair (about 2" by 6") and a small square to put back in on the rear arch to finish off the welding on the driver's side. Passenger side I've a small square to let in on the rear arch and three small patches inside after the MoT advisory rust turned out to be a few small holes. Then there's just two squares to let in to the boot floor, which is a bit involved as I have to drop the petrol tank, and the bodywork is solid again if not the prettiest it could ever be.
After that, the list isn't too bad to get ready for MoT time:
Fit good part worn tyres - freebie from my brother
Change mechanical pump for solid state electric (having oil leak issues with the mechanical one again) - about £30-40
New fuel filter - £2-6, depending on type
Fit good displacer - free, already have the part
Pump up suspension - find someone to come out and do it, usually about £50. Already have the fluid
Fit tow bar - free, liberated from the orange breaker car
Fit interior - removed to do the welding, so free again
Adjust brakes - got the parts, rears seems to be working properly now at least
Then I go through and check everything is working and good, refer back to my MoT fail sheet to check everything is done on that and book her in. Current state of play she's look very much like a 1980s Grandad owns her for allotment and tip runs. I've had the Thule roofrack for ages, but the WINDSLAMMER aerofoil was a recent purchase that I'd forgotten I'd bid 99p on until eBay told me I'd won it.
Xantia is in the bad books too. My brother who used to own the Xantia gave it to me because it kept breaking whenever he tried to use it. I try not to be the superstitious sort so I thought it would be fine for him to have a little drive in it so he could test out the Peugeot seats and the new clutch and let me know what he thought of it. Very nice, was the response from him, far better than when he owned it. What should happen the following day but the glow plug relay was dead as a dead thing. Ordered a 'new' one for a tenner which arrives on Wednesday. Perhaps I ought to be superstitious after all.
