The seller was, as far as eBay is concerned, private. However, I am not too worried about chassis numbers or whatever and, as others have said, a bit of grinding or welding would sort any problems out, though I hope to find the right number (if any) if I have to clean the area off!
I changed the tractors' antifreeze a week or three ago and appear to have more than enough new stuff for the Landy! In a fit of daftness, I checked what was in the radiator and it is adequate for now - though not much more than 25%, where they recommend 50% for the Prima engines. I'll sort that when I get it in the garage - possibly this month!!
In that fit of madness, I started the engine. I suspect the new air filter has helped (and did some stuff I put in the fuel tank) as it started much more easily than it did when I got it. Perhaps that means it will actually accelerate when I take it on the road again! However, I thought the heaters would come on (it was a cold day); so, either the warning light isn't connected, or the heaters don't work: another thing to investigate later on!
The shed is progressing slowly, the delay is partly due to having had a multi-fuel stove fitted in the sitting room - and having to take most of the old fire out before the builder came (and tidy up after him!). I have managed to get the main framework finished (yesterday) and just need some bracing sorted before putting the roof, end and side on. I need a fence panel for the end and have more reed stuff for the side (and three tarpaulins for "doors"), so the only delay is timber - and I can only get a few 2.5m lengths in the Golf. I'll be pleased when the Landy is working - I can borrow my friend's trailer and get much more timber in that! There again, when I've built the shed, I'll hardly need any timber or other building materials. Come to think of it, I'll hardly need the Landy!!
I did make one mistake: I rotavated the "forecourt" in September, intending to level it and sow grass the next day. It poured down that night and has never been dry enough to do anything with it since then! I daren't move the big tractor now the digger is off - there's next to no tread on the back tyres and the loader makes it front-heavy!
