Little bit more done on the tins, managed to get all the major components fitted up
Then...... Took it all to bits and stripped the heads off.
This was necessary to get the missing lower tinware in place (that I didn't have when I built the long block) but simple fix and all the tappers are done now too.
Oil cooler all sealed up and fitting nicely.
And then found something else that doesn't fit properly, stupid pattern parts. Serves me right for starting without having all the pieces and mocking it all up.
Not decided on the fix for this yet as I'm still missing the final piece of tinware to check it.
Then finally the last pieces of the tinware puzzle to deal with,
They are in pretty poor condition but I got them for practically nothing,
After an initial cleaning and quick shot blasting,
This is probably the worst piece of it all,
But after a little persuasion, it's not pretty but then it doesn't have to be where it is just functional.
Couple of new tabs needed on the other side and were good to go,
They just need another clean off in the shot blaster then I'll paint them, maybe with some stone chip if I have any left.
It was then the turn of my cheaply scored alternator off eBay, which came with problems of its own and was probably cheap for a reason. Someone had actually tried welding the pulley to the shaft for some unknown reason.
Anyway, got it all stripped apart.
To be greeted with a load of black tape wrapped around the regulator, some had previously tried to solder this back on which had failed so it was being held with tape. I'm glad now I stripped and checked it.
Then it was just more of the usual, stripping and cleaning.
Not sure wether to carry on polishing or just paint it but I was warned years ago to never paint alternators, so I'm undecided.
Stand came up well though,
This was going to be painted but I think ill just leave it raw now.
Mark.
