ford galaxy
Re: ford galaxy
#231 Post by rich. »
meanwhile in galaxy land the drivers window refuses to open although when i press the button the hazard warning lights flash :? & the central locking has started playing up :evil:
ive had a look at the cables running through the door & one large brown one is broken clean off... any advice would be apreciated im going to try & repair it....
Re: ford galaxy
#232 Post by Luxobarge »
Strip back the wire on either side, and add a small piece of wire in the middle - don't try to overlap the existing wires as they will be too short and will fracture again.
Solder the joints, and insulate using shrink tubing - if you don't have any, get some! It's brilliant stuff, and a soldered joint covered with shrink tube will be about as good a repair as you can ever make.
Give all the other wires a good tug too, because if one has gone then others may well have fractured inside the insulation - a common fault.
Re: ford galaxy
#233 Post by rich. »
thanks mate, ive got it all apart & will repair it tomorrow, there is another cable with the plastic breaking.. ill check the rest as i go along.. although i havant got any shrink sleeving, i will get some next time im in blighty :D
Re: ford galaxy
#234 Post by tractorman »
If it uses the VW colour code, brown will be earth - most confusing to someone used tothe old Lucas code (Brown = fused live)!
Also, if it is like the VW, most of those features go through the "Comfort Unit". It may be worth trying to find it and clean the connectors: it was coded to the last Golf, so might be with the Galaxy too, so no cheap and easy replacement if it's faulty!
Re: ford galaxy
#235 Post by rich. »
fixed :D :D :D although i like the idea of the door loom being connected via a multi pin plug, the actual refitting of the plug is an absolute nightmare.. next time it plays up im selling the flippin thing
Re: ford galaxy
#236 Post by rich. »
took the car out to see a new client (and make the most of the aircon) drove past a camera i see on a regular basis & got flashed :oops: :oops:
Re: ford galaxy
#237 Post by TerryG »
You should call the police. There are laws against that sort of thing!
Re: ford galaxy
#238 Post by rich. »
called the police this morning... doing a flat key handover for a client in town arrived early & the shop below & another flat had been broken into :evil: tools stolen from the neighbours flat & the shop till/safe had been broken into..
a very bizarre start to the day :?
Re: ford galaxy
#239 Post by TerryG »
Le burglers like tools over there then. locally to me they seem to steal oil from central heating tanks more than anything else. Mine has never been touched but 2 others have over the last couple of years.
Re: ford galaxy
#240 Post by rich. »
im not sure what was stolen tools wise but they left a very expensive de walt chopsaw ..just give them a chance terry they will have your fuel away soon!!have you thought of getting a heat pump? the froggies love them as they for the moment are cheaper to run than fuel.. just make sure its set up properly
