Technical help.
Re: Technical help.
#11 Post by tractorman »
Penguin45 wrote:Neon owner speak with forkéd tongue....... I see no reference to dance moves? Anyone would think this was a serious technical discussion......... :roll:
P45.
I suspect Neon Owner has misread the original post (like I did :oops: It was Luxo's post that made me realise the real problem) and thinks the question was about Lambda sensors and not Lambada sensors.
Not that I can advise on dance moves - I can't work the accelerator as I only have two left feet :roll:
Re: Technical help.
#12 Post by rich. »
Mitsuru wrote:The use of cat cleaner
ive tried bathing the cat... wasnt a great.. all teeth & claws..
Richard Moss
Re: Technical help.
#13 Post by Richard Moss »
We will have to take steps to get it back on track.
I wonder if you can repair a Lambada sensor with metal from an old Tango can? Or even a Tango Can Can (so that you can do the downstream Lambada sensor, too).
Re: Technical help.
#14 Post by tractorman »
Perhaps that's why a cat cleaner is useful. Mind you, I find the pressure washer at full tilt usually does a pretty good job.
Our last cat used to sleep in the bath when he was younger. That stopped after he rushed into the bathroom and jumped in without thinking - mother was filling the thing - the cat jumped out very quickly!
Re: Technical help.
#15 Post by UKJeeper »
Re: Technical help.
#16 Post by Mitsuru »
Better off setting up a lawn sprinkler where the blighters do their unwanted business
in the garden and sit near the tap. You may be out of using the hose pipe distance by
the time they see you walking towards them with the hose, but not a well laid sprinkler
:twisted:
Yes the blighters spray their cent and screech outside my window! Air rifle or shot gun
next?
jimmyybob
Re: Technical help.
#17 Post by jimmyybob »
Small technical point, there is no such thing as a Lambda sensor.
Lambda is the Air–fuel equivalence ratio the sensor in the exhaust is an O2 sensor that then works out the ratio and sets the engine to Lambda 1
Re: Technical help.
#18 Post by TerryG »
There definitely is such thing as a lambda sensor. It is what certain manufacturers chose to call an oxygen sensor.
Do you do the hovering or vacuuming?
Fatbloke
Re: Technical help.
#19 Post by Fatbloke »
TerryG wrote:Do you do the hovering or vacuuming?
Neither...I have a Mrs FB for that!
Visiting hours at the Hospital are 4PM to 8PM if anyone wants to watch me take my meals through a straw
Mike.
A Fatbloke in a Herald
Re: Technical help.
#20 Post by tractorman »
TerryG wrote: Do you do the hovering or vacuuming?
Hmm, it's donkey's years since I saw a hover vacuum (Hoover made one in the 50s/60s - the "Constellation"):
In my case, I Hoover the carpets, Silverline or Aqua-vac the car (or workshop, Rayburn flue etc), Karcher or Daewoo the stairs or fiddly bits (on rare occasions) or, if I am really sad, Vax the computer keyboard/motherboard! A friend insists he (ie his wife) Hoovers with their Dyson :roll:
Being pedantic, I don't think something for detecting a particular mobile phone service provider is actually used in car exhausts!!
EDIT: changed the link to show the Hoover - I hadn't noticed that the original picture didn't show correctly (I thought it did when I did a preview!)
