MGF's or whatever they are
Re: MGF's or whatever they are
#11 Post by mach1rob »
STOP! :P A cheap F may be an expensive one in the long run.Make sure there's no structural rot in the screen surround, can be a killer if it gets bad It's what killed mine, rust, was a bit scabby everywhere tbh, so worth checking, photos hide it a treat. They are well catered for parts wise, most bits can be found in a Metro (R100) R200 etc mechanical wise, even the odd bit of trim and switchgear.
They do go well, especially the VVC, and nice if the suspension is pumped up (even if they do look like they're on stilts) rather than fluid being let out to lower them, it's like driving a car with no suspension as they bottom out over a pebble. Cooling can be an issue, the pipes running under car can rot and are susceptible to damage leading to coolant leaks or total loss, stainless steel replacements available around £70ish. Gear linkage can be a bit vague and sloppy, but you get used to it. Hoods can leak leading to wet carpets behind the seats as that's the lowest point, although poor alignment and seals can leak water in around the glass, and it's not unknown for windows to get stuck behind the seals, so opening the door becomes difficult unless you drop the window first. Not to hard to make adjustments to seal and window itself.
As for the K, well yes HGF is well noted, however, I suspect many diagnosis's of HGF was just the inlet manifold letting go, as that pumps coolant straight into the combustion chambers, but uprated gaskets, along with steel dowels, along with new uprated inlet cures the problem. A PRT stat is also a good idea, along with a low fluid level warning kit. Engine access is a pain, there's room to work with small hands, but to actually get to it, you have to pop up rear of roof, remove the parcel shelf carpet and sound deadening, then the access panel which has around 10-15 bolts holding it in. Dipstick etc are easily accessible from the boot though (as is bonnet pull!)
zipgun
#12 Post by zipgun »
Go on , Terry , get it. More i look at it,(and i do like it ), its a "im..practical" classic ! Look at the size of the boot :lol: I, or the misses couldn't live with that as a daily. Me 899cc Cinquecento'll have to serve a bit longer ! :cry: Is the MG "T"F much the same car just a different nose?
#13 Post by mach1rob »
Yes but no, the TF lost the hydragas suspension and went traditional spring and shock route. Some say better, some say it lost its edge.
#14 Post by JPB »
mach1rob wrote:STOP! :P ....
If anyone else had said that I'd worry, Terry! ;) Dolomites and TR7s with MGF wheels aren't unheard of and the K series is an upgrade for one famous, non-standard but more effective competition Dolly. (Google for Ken Wood's well known, largely GRP panelled rally Dolomite, don't just take my word for how well they can go). OK, you got me but did I actually say 4 cylinder K series? :lol:
Oh go on then, here's Ken's rally weapon doing its thing. Sound up for this vid please!
:D
#15 Post by TerryG »
Does the KV6 fit, I know where I can get a pranged v6 rover 75 for peanuts ;)
zipgun
#16 Post by zipgun »
Didn't you see the MX3 1.8 v6 for sale on that site. Far more hornier noise :P (look at the rev counter mmmm, a 7000 redline :mrgreen: ) and practical , similar mileage and vgc .Cheap too!
But it's red :cry:
There ya go. Loads of seemingly genuine cars on that site at enthusiast prices? http://retrorides.proboards.com/thread/ ... g17-months
#17 Post by mach1rob »
TerryG wrote:Does the KV6 fit, I know where I can get a pranged v6 rover 75 for peanuts ;)
Yes :D Tight as, but they do go in, even MG-R were developing one before things went breasts skywards.
http://www.aronline.co.uk/blogs/concept ... -mg-tf-gt/
KV6 TF
http://www.youtube.com/watch?v=bez0AqDUkpk
#18 Post by TerryG »
now all I need is the MG-F and a really big shoe horn........ ;)
#19 Post by JPB »
Save yourself the hassle, buy a Suzuki Grandiose Viagra and have room to work on the engine. ;)
Sorry, wrong KV6. :oops:
#20 Post by mach1rob »
Change the cambelt while engine is out, you'll have room! ;)
