radio and clock
Re: radio and clock
Re: radio and clock
Why not? Taking it to pieces is easy. It's putting it back together again that is difficult
Re: radio and clock
Nah, it's easy too, in fact it's what digital cameras were invented for! Take loads of pictures from every angle at every stage and you can't go wrong.
Re: radio and clock
Re: radio and clock
Not a problem. Measure their runs with a bit of string and I'll get a set to you. There'll be a flat belt that runs on the crown of the motor and the rim of the flywheel, a square or round one that runs from the flywheel back to the idler hub and a counter belt if the machine has a counter. The idler tyres and the pinch roller may also be softening so if they're all ok get them out and soak them in glycerine overnight to prevent any further deterioration and make them usable.
That's option one, option two is stick a bunch of your postie's finest rubber bands on it then get it back on eBay while it runs.
Re: radio and clock
Das awful kind fella , N2204 belts are still listed on ebay 6 quid ish. What does this goo disolve in ? Acetone, cellulose or white spirit ? or water
What makes it go like this anyway, heat ? I thought it woulda just gone hard and brittle
Re: radio and clock
This thread brings back memories, I've still got one of those, plus the car mounting kit. Not sure what state it's in though.
Re: radio and clock
The best and - least harmful way - to clean it away is to use contact spray, Maplin sell a Servisol one (not S10, which includes lubricant and you don't want that) but the cheapest and most effective is the Halfords one at £4 for a much larger can.zipgun wrote:Das awful kind fella , N2204 belts are still listed on ebay 6 quid ish. What does this goo disolve in ? Acetone, cellulose or white spirit ? or waterWhat makes it go like this anyway, heat ? I thought it woulda just gone hard and brittle
You may have to pull the capstan bearings to get all of the molten rubber out though, not too difficult with some BA sockets and a decent pair of Moles.
Soak the bearings in (non-EP) gear oil overnight - as you would with any Oillite bushes - before pressing them back into their block.
The belts go that way as a result of people killing their equipment with kindness. Far too much of the wrong sort of head cleaning chemicals eventually do this. I have a big JVC that I've owned from new and that's never had any unsuitable substances in about at its rubbers, consequently it still plays, fast winds, searches and cues at the right speeds, just as LL Cool J would want it to do.
