Proffesional get my vote.
Rust proofing, DIY or profesionals
- M Paul Lloyd
Re: Rust proofing, DIY or profesionals
Anyway, I have just had my car done professionaly (350gbp for a 4 door saloon by Si Jackson at Wax Works, 3 Coopies Way, Morpeth ) mine is not a classic but I want to keep it and to be honest, unless you have a large well ventilated working area with no close neighbours, two post lift, exceptional cleaning gear, high pressure waxing rig and a slightly masochistic propensity I would not choose to do it myself.
- TriumphDriver
Gawd we're getting spoilt these days. I regularly do the Landy with an old shower curtain on the ground and a schutz gun full of Waxoyl. I keep two aerosol cans in the boot for touch-ups after powerwashing. The Triumphs are jacked off the ground as high as they will go, first front then rear, and sprayed in the same manner with all drain holes and chassis apertures sprayed with a long nozzle. £350 is a lot of money for something that requires repeating every year.M Paul Lloyd wrote:Unless you have a large well ventilated working area with no close neighbours, two post lift, exceptional cleaning gear, high pressure waxing rig and a slightly masochistic propensity I would not choose to do it myself.
m.thaddeus
Hello Chaps
Wax injection is as smelly and messy a job as you can ever do. I have done a few and usually spend more time cleaning up afterwards as doing the actual job.
I set the car on stands remove as much trim in and out as is practical and set to with the injection lance and paintbrush for all the seams and back edges and trims etc. And when it all done. the whole car has to be wiped with panel cleaner ( at least twice) and then given a damn good waxing. Then you put all the trim back and clean the car again. During this time you will have washed you hands a dozen times.
The upshot is a very shiny car which stinks and will drip wax in hot weather. Worthwhile and actually very satisfying.
If you can do it yourself. I charge about £300, but for the hours involved that is not a lot.
Regards Martin
Regards Martin
- M Paul Lloyd
Point taken, I have become lazy in my old age,TriumphDriver wrote:Gawd we're getting spoilt these days. I regularly do the Landy with an old shower curtain on the ground and a schutz gun full of Waxoyl. I keep two aerosol cans in the boot for touch-ups after powerwashing. The Triumphs are jacked off the ground as high as they will go, first front then rear, and sprayed in the same manner with all drain holes and chassis apertures sprayed with a long nozzle. £350 is a lot of money for something that requires repeating every year.M Paul Lloyd wrote:Unless you have a large well ventilated working area with no close neighbours, two post lift, exceptional cleaning gear, high pressure waxing rig and a slightly masochistic propensity I would not choose to do it myself.
