Task number two was to cover up some of the bare metalwork on the rear of the car. This has wound up with the whole thing encased in duct tape for now, looks horrific, but at least there are now no sharp edges accessible. I'm sure a bunch of these cars were largely held together by gaffer tape back in the day too.
No, I'm not proud of it. It's a means to an end - I want to drive the thing, and don't want to wait until I can put aside a couple of complete afternoons with decent weather to attack it with fibreglass.
The offside front corner has had a steel band added to reinforce it, and has been similarly plastered in tape. I've also stuck a patch on the hole in the roof primarily to assist in keeping the weather out.
Speaking of keeping things in or out, I'm glad to see that the lock on the front service cover has freed up after a couple of months of regularly dosing it with penetrating fluid.
Nice the way stuff seems to keep coming back to life.
With this all done it was time to go for today's test run. After a little noodling around our estate again I decided that it was time to try the higher speed run. No horrors to report. Managed to get up to just under 50mph before having to brake for the roundabout at the bottom of the hill. On the way back progress was slowed a bit, but still got up to 40 or thereabouts. The only slightly unnerving aspect was that she briefly decided not to give me any power when I intitally went to pull onto the roundabout coming back - a fraction of a second's delay and audible pop back through the carb and she was off again. I've notice this happen a few times on roughly half throttle. Guessing there's still a bit of crud floating around in the carb.
On arriving back from that run (wanting to give thigns a check over given it was the first time she had exceeded 30mph in quite a while), there was quite an odd "hot" smell - which I reckon was coming from the paint on the silencer after a bit of checking. The popping back through the carb I reckon is the reason that the carb itself was damp with fuel.
The carb being cold I think was the only reason this hadn't evaporated pretty much as soon as it had ended up there. I'll keep an eye on this.
I then went about a little further local testing, getting a little more used to the controls meant that a certain degree of mild hooning may have taken place. It's a long while since I was last in a Reliant, but to my mind this definitely feels less tippy when you throw it into a corner or roundabout.
I did attempt to get some video footage of the test drives - but managed an epic fail today on a video front. Attempt number one went just fine until the first roundabout was taken at any speed...at which point the phone fell out of where I'd wedged it. Attempt number two would have been fine if the phone hadn't wound up pointed mostly at the ceiling. I'm going to try to dig out the Not-A-Go-Pro tomorrow and use that instead as it at least has some proper options to secure it to the car. If you guys want me to upload the video I do have just let me know...You can kind of see what's going on and have the audio to go with it.
So, stuff I've ascertained today:
[] Oil leak from dipstick might be fixed.
[] The grounding arrangements in these tail lights is epically rubbish. I may wind up improving this myself to save me trouble in the long run.
[] Handling is better than I expected. I reckon you could actually chuck this car around quite a bit once you're used to it.
[] On the same topic, the suspension and steering feels really tight. No knocks, clonks or obvious play in anything like that.
[] Ride is pleasantly compliant, bit of a surprise given how light she is.
[] One horrible noise which has turned up a couple of times is the guard touching one of the pulleys very lightly - mainly just as you come off the throttle. I will sort this using a small amount of violence shortly. I know what it is though and it sounds way worse than it actually is.
[] 50mph looks to be doable without too much trouble.
[] Occasional miss/backfire on part throttle needs an eye kept on it.
I needed to go to the nearest supermarket for one or two things this afternoon and very nearly took the Invacar...Sadly I chickend out. Maybe tomorrow.
Definitely overall seems to be running better. The drive system seems to be behaving itself pretty much as I'd expect now, I think the biggest thing which initially was throwing me off is just the level of overall noise involved with the engine running at the speed it needs to for the clutch to engage. Was really glad to see that once up to speed that there weren't any unpleasant noises or vibration which would suggest duff wheel bearings or any boring problems like that needing attention.
