I have new chain, guides, tensioner, sprockets etc along with a fresh cylinder head, cams and required bits and bobs.
My problem then, being a modern is that I know squat about injection and ignition. So, I can get TDC on cylinder 1, and set the cams and valve timing to this no bother so that it is on the compression stroke.......
But how do I figure the correct TDC in relation to being in the correct position for the fuel injection and ignition timing ? i.e could I set the valve to piston timing correctly, but then have the wrong timing in relation to spark and fuel delivery ?, and how would I set this up.
Thoughts please or am I thinking too hard about it..... would like some thoughts / guidance before tackling it.
